Discussion topic: Downloads via Sky on go slow
This message was authored by SOOKIE+D This message was authored by: SOOKIE+D
Been Sky Q user for many many years. Over last couple of months, downloading anything or watching on demand has ground to a halt. Have always been used to just hitting 'watch' for a film and you can begin watching within a minute or two. Now picking a film to watch for the night, it's taking hours and hours to be able to watch. There's nothing wrong with fibre broadband speed (but we've rebooted everything just in case) and if I use other streaming apps via TV eg Netflix app rather than via Sky, it's absolutely fine. Have tried everything and now just furious at how useless it's become. Any ideas as nothing else has changed?
Re: Downloads via Sky on go slow
Hi @SOOKIE+D
SOOKIE+D
Thanks I can give this a go. Sorry to ask a stupid question but do I do this on the main box or for each mini box too?
Just the Main Q box @SOOKIE+D
