Discussion topic: Volume control with Bluetooth
Message posted on 24 Nov 2025 12:10 PM
Can I control sky Q box with Bluetooth rather than infrared as I don't have line of sight to box
Message posted on 24 Nov 2025 12:15 PM
Re: Volume control with Bluetooth
If you have a Bluetooth remote, yes, assuming it's within range. Not all Q remotes are Bluetooth, but all the models with Voice Control are.
Message posted on 24 Nov 2025 12:31 PM
Further to @TimmyBGood 's reply, you need to be aware that only one remote can be paired in bluetooth mode & you do need to have line of sight when pairing etc.
I have my box out of line of sight on a shelf behind my TV & just for test purposes have found that the bluetooth has a very good range (I have used it in my back garden when my box is in my front lounge near the window)
Message posted on 24 Nov 2025 12:35 PM
The question title is about how to adjust volume with the bluetooth remote. As far as I recall, the on/off and volume controls are IR and not bluetooth.
Pete.
Message posted on 24 Nov 2025 12:42 PM
Ah yes I forgot the title after reading the actual post & @TimmyBGood 's reply
@Ross1948 just for clarity the Volume control is direct from the controller to the TV & does not route via the SKY Q box and. as @PeteRG41 mentions, only uses IR for this but I doubt that TV IR receiver is out of line of sight of the controller
