This discussion topic has been answered Discussion topic: Audio drops on Sky Q Mini
Message posted on 05 Oct 2025 06:41 PM
I'm getting regular audio drops for up to 2 seconds, on my Sky Q mini. I've done a full reset, changed hdmi cables, hdmi inputs on TV. I've even changed to Ethernet connection rather than wi-fi. Changed audio to normal, but still the same. Not sure what else I can try? Any ideas?
Message posted on 24 Nov 2025 01:07 PM
I resolved my issue by ditching the Ethernet connections and switching to WiFi. Sound issue resolved after switching to WiFi
Message posted on 05 Oct 2025 08:01 PM
Re: Audio drops on Sky Q Mini
when you switched to ethernet, did you disable wifi on the mini?
Message posted on 06 Oct 2025 12:04 PM
Yes, both channels were disabled. Definitely now connected via Ethernet.
Message posted on 24 Nov 2025 01:02 PM
I have the same issue. I too have both the Sky Q main box and Mini box connected via ethernet cables. The Q main box has no audio dropouts but the Mini box drops for 2 seconds about every 3 minutes. Very annoying.
The Mini box is connected direct by ethernet cable to my BT Hub router, the Q Main box is connected by ethernet cable to a Devolo extender which is using Powerline to distribute WiFi around the house.
I have disabled the WiFi connection on both Q boxes.
Any other ideas???
The Sky help pages are not helpful.
