3
This discussion topic has been answered Discussion topic: Volume control SkyQ remote sudden failure
This message was authored by: dcarr2
Samsung smart TV is connected to Skyq box and its remote used also to control volume on my Sonos Beam soundbar. All working properly for years but last night out of the blue, the volume on my Sky remote becomes not adjustable. Every other function is normal. Have tried re pairing and can use the Alexa feature in the soundbar to shout a volume change. The actual TV remote is not used but also its volume is also not in action,  how can I try to get back to my Sky remote's normal use, please?
This message was authored by: Addie15 Answer
Re: Volume control SkyQ remote sudden failure
This message was authored by: rob304
my sky box isnt working   NOW WHAT HJAPPENS
If you go through this troubleshooter it will lead to a box replacement request if necessary.
Make sure you keep your viewing card and also swap the power cable with the box. There are two types.
https://www.sky.com/help/articles/sky-box-problems-t2
p,s. Your caps lock key might need checking out too.
