Discussion topic: Sky Q box repeated gets stuck when it goes into standby
This message was authored by: Martinjc1972
Every morning and evening the box has gone into standby and cannot get it to turn on without unplugging it. That fixes it until it goes into standby again. The box is making a lot of noise but is not hot
Re: Sky Q box repeated gets stuck when it goes into standby
Hi @Martinjc1972
Try a Reset Settings in the Q box hidden menu.   See if that helps.
