Discussion topic: Voice guidance
Message posted on 09 Nov 2025 12:14 PM
Is anybody having an issue with voice guidance option in accessibility settings on a Sky Q box? My voice guidance stopped working on Friday. Sky tech support went through every possible fix including a factory reset but didn't solve the problem.
Message posted on 12 Nov 2025 07:21 AM
Hi Everyone
Our support teams have advised that they believe this issue is resolved.
Is that the case for you?
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Kev
Community Manager
Message posted on 09 Nov 2025 12:25 PM
Re: Voice guidance
Hi @Max641
Have you checked that your Q box HDMI Audio is still set to Normal?
Found in Home - Settings - Setup - Audio visual.
Voice guidance will not work with Dolby audio settings.
Message posted on 09 Nov 2025 12:49 PM
Re: Voice guidance
Hi Max641
yes, same problem here. Stopped working on Friday too. I have done all resets and tests and it will not come back on. At least one other person has also mentioned that the same has happened , on the accessibility section of the forum.
looks to me like the problem is Sky's end.
Message posted on 09 Nov 2025 01:01 PM
Re: Voice guidance
Yes, it's set to normal but still not working. Strange that tech support never suggested this as a possible solution🤔. Thanks for the advice👍
Message posted on 10 Nov 2025 10:10 AM
Re: Voice guidance
I've been having trouble since Friday too. Was told it's a problem with them and they are working on it.
Message posted on 10 Nov 2025 10:13 AM
Re: Voice guidance
It is at sky end, that's what they told me. Said they was working on it. I don't think they must be. Not good enough!
Message posted on 10 Nov 2025 01:17 PM
Re: Voice guidance
Hi Everyone
Thank you for coming to the Community to tell us about this problem.
We apologise for the inconvenience this may be causing and want to make you aware that our engineers continue to work on the problem with priority.
Kev
Community Manager
Hi Everyone
Kev
Community Manager
Message posted on 12 Nov 2025 11:30 AM
Re: Voice guidance
Mine is now working again. Many thanks
