Discussion topic: Voice Command
This message was authored by: MikeGreg
Voice Command
Towards the end of its life my voice command worked with everything accept when you say 'prime'. It would register you had said it on the TV screen but channel wouldn't change. All other commands worked.                                      Just got a new remote and got the same issue!
Re: Voice Command
hi @MikeGreg
What are you trying to access - is it Amazon Prime app or a TV Channel (I don;t know all the channels there are)
If it is Amazon Prime - please try saying Amazon Prime
If it is a TV channel is there a longer name you could use  ?
Alternatively try 'Channel nnn' where nnn is the channel number
This message was authored by: Invisiblename
Re: Voice Command
@nigea99 wrote:
hi @MikeGreg
@MikeGreg  The above is correct, saying "Prime" will not open the Amazon Prime app, you need to say "Amazon Prime"
I am just another Sky customer!
Avatar for MikeGreg
Re: Voice Command
Thanks to everyone, it does work when you say Amazon Video. Just don't understand why up until last month I could say just 'prime,'
Re: Voice Command
hi @MikeGreg
They do adjust the keywords from time to time & there may be a reason  why they changed this (maybe something due that could be confused with it). although we have no idea if this is the case or why..
