11
This discussion topic has been answered Discussion topic: Viewing card
This message was authored by: Tim2024
Viewing card
My sky box has come up with the message 'please insert your viewing card with the chip facing up.
the viewing card has not been removed. I have rebooted the sky box and reinserted the viewing card. The  same message is still there
This message was authored by: SKY1992bf Answer
Re: Viewing card
@Tim2024  You are the second person to post this issue tonight
If you've got Sky Q, then you will have a viewing card in the slot on the side of your box.  If you push it gently in, it should then pop out. Give the chip face a wipe with a soft, dry cloth, push it back in the same way up as it came out, and see if that sorts it.
Re: Viewing card
Re: Viewing card
@Tim2024 You could try refreshing your viewing card by
pressing home > settings > system info > viewing card number > setup > viewing card setup
press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Chell3003
Re: Viewing card
I've done this
This message was authored by: ThePope27
Re: Viewing card
@Laing1,
You can't do a callback if the box thinks the card isn't inserted 🙂
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
This message was authored by: Jackdaniel98
Re: Viewing card
Hello I need a new viewing card as I left it in the old box
Re: Viewing card
@Jackdaniel98
I'm afraid the only way to do this now is by calling Sky. The Messaging Team on here can't action that request any more.
This message was authored by: Aub
Re: Viewing card
Hi I have just received a new sky Q box and unfortunately i left the viewing card in the old box they took away
Re: Viewing card
@Aub  You need to call sky and order a replacement
This message was authored by: AlanT2
Re: Viewing card
Hi I'm not looking to reply to anyone I have simply lost all hope in trying to get an answer on where my viewing card is. I never received prior to installation and was told it was expressed posted on Dec 23rd. Take into account the Christmas stoppages, I still have not received it and nobody has made contact with me with a tracking reference number or any sort of update, not even an apology to say it should have been posted 14 days earlier. I truly have no door left to open and I cannot speak to that customer service Centre again.
Re: Viewing card
@AlanT2
My son had Sky Q installed on 23 December but his viewing card hadn't arrived. Luckily the engineer had spares in his van. The viewing card eventually arrived on 31 December. They are sent via Royal Mail so you are relying on your Postie.
This message was authored by: Sarah619
Re: Viewing card
Just followed this advice as I had the same issue with my viewing card and it fixed the issue. Genius- thank you so much
