This discussion topic has been answered Discussion topic: Viewing card
Message posted on 03 Apr 2024 07:38 PM
My sky box has come up with the message 'please insert your viewing card with the chip facing up.
the viewing card has not been removed. I have rebooted the sky box and reinserted the viewing card. The same message is still there
Message posted on 03 Apr 2024 07:42 PM
@Tim2024 You are the second person to post this issue tonight
If you've got Sky Q, then you will have a viewing card in the slot on the side of your box. If you push it gently in, it should then pop out. Give the chip face a wipe with a soft, dry cloth, push it back in the same way up as it came out, and see if that sorts it.
Message posted on 03 Apr 2024 08:19 PM
Re: Viewing card
@Tim2024 You could try refreshing your viewing card by
pressing home > settings > system info > viewing card number > setup > viewing card setup
press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Apr 2024 12:41 PM
Re: Viewing card
I've done this
Message posted on 21 Apr 2024 12:57 PM
Re: Viewing card
You can't do a callback if the box thinks the card isn't inserted 🙂
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 23 Jul 2024 04:02 PM
Re: Viewing card
Hello I need a new viewing card as I left it in the old box
Message posted on 23 Jul 2024 04:07 PM
Re: Viewing card
I'm afraid the only way to do this now is by calling Sky. The Messaging Team on here can't action that request any more.
Message posted on 10 Nov 2024 02:55 PM
Re: Viewing card
Hi I have just received a new sky Q box and unfortunately i left the viewing card in the old box they took away
Message posted on 10 Nov 2024 02:57 PM
Re: Viewing card
@Aub You need to call sky and order a replacement
Message posted on 02 Jan 2025 05:27 PM
Re: Viewing card
Hi I'm not looking to reply to anyone I have simply lost all hope in trying to get an answer on where my viewing card is. I never received prior to installation and was told it was expressed posted on Dec 23rd. Take into account the Christmas stoppages, I still have not received it and nobody has made contact with me with a tracking reference number or any sort of update, not even an apology to say it should have been posted 14 days earlier. I truly have no door left to open and I cannot speak to that customer service Centre again.
Message posted on 02 Jan 2025 05:33 PM
Re: Viewing card
My son had Sky Q installed on 23 December but his viewing card hadn't arrived. Luckily the engineer had spares in his van. The viewing card eventually arrived on 31 December. They are sent via Royal Mail so you are relying on your Postie.
Message posted on 06 Feb 2026 08:50 PM
Re: Viewing card
Just followed this advice as I had the same issue with my viewing card and it fixed the issue. Genius- thank you so much
