Discussion topic: Viewing card problem
Message posted on 24 Jan 2024 01:32 PM
Message posted on 24 Jan 2024 01:35 PM
Re: Viewing card problem
@EMILYSTINSON
If you definitely need to contact Sky, (and as long as your services aren’t restricted) then if you already have a Sky Mobile or a Sky Talk landline call free by dialling 150, otherwise you can use:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and it provides a 0333 number.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a 0818 number.
(The forum doesn’t allow us to type the numbers in full).
You will find that similar to calling other large companies the start will be automated which may also try to send you back to the forum. Stay on the line as long as possible.
Note: We were informed recently the lines were busier than usual so try to pick a quieter time.
