Discussion topic: Viewing card not working
Message posted on 26 Sep 2023 06:34 PM
TV say please insert your viewing card with the chip facing up.i have not removed the card
Message posted on 26 Sep 2023 06:37 PM
Re: Viewing card not working
Hi @scs8579
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 17 Nov 2023 11:05 AM
Just started working again, must be a ghost in the house! So sad Sky charge so much and you cant even call anyone for help. THE RICH GET RICHER
Cheers
Message posted on 11 Nov 2024 10:33 PM
I've followed these step but it's still not working
