Discussion topic: Viewing card issue
This message was authored by: Sam384
Viewing card issue
Contacting Sky to let them know - it's the correct card and the right way up but not working - going round in circles on the information and links
Re: Viewing card issue
Except you're not contacting Sky customer services by posting here, no one knows who you are.
You origially posted this in the broadband board but broadband is not reliant on viewing cards, so the question is which box do you have Sky+HD  or Sky Q?
Avatar for Sam384
Hi GD1
This was where i was directed when i was searching for support for the viewing card on Sky.
So sorry for posting on the wrong board. I have a Sky Q box.
Avatar for Sam384
Thank you for replying GD1
I was searching through the website going  round in circles and this was suggested as a place where i could find an answer, sorry if its not the right place.
I have a sky Q box  not recognising the card that was working fine previously.
@Sam384
First check that your viewing card is correctly inserted. If it is in correctly there is not enough of it showing to grip and remove it. Push it fully in and it will pop out slightly so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth. Once it's dry reinsert it chip side up and chip end in first. Push it gently fully in and you should hear  a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If the message still appears try refreshing your Viewing card. So go to…
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback. (No phone call is made, it's just Sky terminology but the card should he refreshed).
