19 Sep 2023 06:40 PM
I have just had a replacement viewing card and it's not working
19 Sep 2023 06:54 PM
Hi @Richyp1780
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly thereis not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that is chip side up and chip end in first. Push it gently full in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
