Discussion topic: Very frustrated
Message posted on 12 Oct 2024 02:24 PM
Very frustrated
Any ideas gratefully received
I have tried all and multiple unplugging and replugging in the router, sky box etc etc. left them off for a time. Plugged them back in router first, let it boot up and turn on the box. Tried the connect button on both. Still no network connection. Alexa, phones etc all connected to the WiFi. Any ideas or a number for Sky help please xx
Message posted on 13 Oct 2024 05:04 AM
Re: Very frustrated
Have you gone to settings and checked your whether your Network connection has a tick beside it. If it doesn't have a tick beside it, click Network connection, then select Network setup, then Advanced settings, then reset. Select your broadband and use your handset to put in your wifi password.
Message posted on 13 Oct 2024 09:37 AM
Re: Very frustrated
Thank you I'll try it x
