Discussion topic: Problem with watching discovery plus, not in my sky shop or market place to try to watch
Message posted on 18 May 2024 11:25 AM
problem with discovery plus, not showing in my market place or sky shop to activate need help please
Message posted on 18 May 2024 11:42 AM
Re: Problem with watching discovery plus, not in my sky shop or market place to try to watch
Sky Q
Press Home, then scroll down the menu and select My Sky.
Or press the Voice button on your Sky remote and say “My Sky”.
Select discovery+. If you can't see it, select Browse Shop then discovery+.
Above taken from link below
https://www.sky.com/help/articles/sky-marketplace-subscribe-to-apps
Message posted on 18 May 2024 12:43 PM
Message posted on 28 May 2024 02:09 PM
Ive been having the same problem discovery plus isnt in my sky shop or market place I'm so feedup with this issue
Message posted on 28 May 2024 02:14 PM
Its ok when the discovery plus app is there in sky shop to click your what to do where followed to the letter like the many other users someone needs to really get there finger out and fix this issue its been going on for months.
your Colin
Message posted on 01 Jun 2024 07:45 PM
This does not work if the Discovery+ app is not in Sky Store. That is the propblem I have, same as others on this problem stream.
Message posted on 01 Jun 2024 08:19 PM
Hi Graham as I've been having the same problem go direct to discovery plus and phone them explain what's happened to you give them the details they ask for I did they then gave me two months free voucher put straight to my sky and hay press toe discovery plus works straight out the box as it should do hopefully it helps you out seeing SKY are short on help .
Message posted on 04 Jun 2024 04:58 PM
Thanks Colin, like a lot of people I was wanting to see the European Champions League final. I ended up ctreating a Discovery+ account on my laptop and signing in to Discovery+ on an Amazon Firestick I also have in the TV. There is not much else on Discovery+ that I want to watch, perhaps the French Open but two Eurosprts free channels are showing most of that.
Thanks for the help in any case
Graham
Message posted on 05 Jun 2024 07:56 AM
If you're fault is anything like mine - Not had Discovery+ since Sept 2023 when I unfortunately rejoined Sky, After all types of promises, missed calls and early closure of the problem by Sky I reported the matter to CISAS who took on my case. CISAS are totally independent and found in my favour, stating that Sky did not act reasonably, that they had shortcomings including missed calls and premature closure of my complaint. CISAS further stated Sky's failure to provide Discovery+ was a significant inconvenience and a significant cause of distress to the customer. CISAS also stated that whilst DIscovery+ was provided free by Sky the prolonged unavailability means Sky is not providing something it said it would and that consumer law gives the customer a right to a price reduction.
In conclusion I was awarded compensation and that Sky must update me to the status of the investigation. Todate Sky have paid me the compensation and updated me once! I still have no Discovery+ and am currently looking to further legal action against Sky.
Message posted on 21 Sep 2024 11:07 PM
I am struggling with exactly the same problem. No discoveryplus in the sky marketplace.
Isn't it about time sky sorted this?
Message posted on
13 Oct 2024
02:22 AM
- last edited:
14 Oct 2024
09:17 AM
by
Daniel-F
(Removed) discovery plus is not available at no extra cost, it's not available at all, whenever I try and watch anything it says I need to upgrade.
ive tried every step by step how to etc etc and NOTHING WORKS!!
I don't get how such a large company can get away with blatant lies and they make no effort to help anyone.
and trying to speak to someone on the phone regarding this issue??
you may as well phone the moon ....
Moderator note: Removed inappropriate language
Message posted on 13 Oct 2024 08:48 AM
Do what I did report them to CISAS. This is an independant body, provide them with as much information as possible i.e. dates of phone calls, responses from Sky, basically whatever info you can collect. CISAS found in my favour and I was awarded £100. I have been without Discovery+ for a year now my contract is due Feb 2005 which I will not be renewing. CISAS also stated 1. Sky did not act reasonably. 2. Short comings in Sky response. 3. Sky caused inconvenience and distress to the customer which was significant 4. It may be free but its prolonged unavailability means Sky is NOT providing the service it said it would. Consumer Law gives the customer a right to a price reduction.
Hope this helps.
