Discussion topic: V fulli
This message was authored by: judithjeff
V fulli
Ive had tbis Q box just over a week and we keep getting a break in the picture with a message V Full. Ive rebooted it umpteen times but it still comes up. Advice to resolve please
Re: V fulli
Hi @judithjeff
Doesn't seem to be a Sky Q message.
See if your TV set remote will clear it.
Re: V fulli
@judithjeff
I too have never seen such a message from a Sky device or the mention of such a message on the forums before.
Avatar for judithjeff
Re: V fulli
Never had any issues with my old sky box. Its only happened since i got this new one
Re: V fulli
@judithjeff  As advised that is a TV message you'll need to use your TV remote to clear it, it's not a message from your Sky Q box
This message was authored by: SlenderRobert
Re: V fulli
Turn your Q box and the TV off and make sure the HDMI cable is fully inserted into the back of the Q box and into the TV, then power them back on.
'V Full' sounds like it is generated by the TV when it detects a break in the signal so it may just be that the HDMI cable hasn't been fully re-inserted when you had the new box fitted.
Re: V fulli
Yes the V Full message is what  get on my Panasonic  TV when switching to a HD source
You should not be getting this other then when you first switch to SKY
@judithjeff  as  @SlenderRobert suggests I recommend taking the HDMI Cable out and then putting it back in making sure it seated properly in both the SKY Q box & the TV
Re: V fulli
Ive a panasonic tv too. Thanks
Re: V fulli
Unplugged everything reconnected and rebooted and up to now it hasnt re-occured. Thanks for advice
