Discussion topic: My sky box won't connect to Internet, but other devices can connect
This message was authored by: Mel.+Robertson
I can't connect my sky box to the Internet. Other devices are connected so it isn't an Internet provider issue.
I have tried resetting Internet but this hasn't worked
Re: My sky box won't connect to Internet, but other devices can connect
Hi @Mel.+Robertson
Assume you are referring to main Q box?
Have you tried a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
