Discussion topic: Using mobile as remote
Re: Using mobile as remote
@DiMach6695 wrote:
I can assure you I have updated the app and it's still not showing on the My Sky app for android, otherwise I wouldn't have asked.
hi @DiMach6695
Is the device connected to the same network as your SKy Q box ?
I am guessing you don't have an old version of android but  I probably should ask just in case (I haven't looked up which version it does need )
BTW I realised you wouldn't have asked if you could see it.
This message was authored by: DiMach6695
One UI V 7.0
Android Version 15
And yes same network.
@DiMach6695 are you looking on the My Sky app or the Sky Go app as there are no remotes on the MySky app and guessing that was a typo from you but you need the Sky Go app for the remote control
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Problem fixed. Thank you brother
This message was authored by: ollie261
thank you
need to use fone for the remote
Are you just telling us or do you have a question about that?
