Discussion topic: Using mobile as remote
Message posted on 11 Dec 2023 11:16 PM
Message posted on 12 Dec 2023 06:45 AM
Re: Using mobile as remote
@Hjbradn115 wrote:
My sky Q remote has broken and I have another ordered but in the mean time I wanted to use my ojone as the remote. In the sky Q and sky go app I should be able to go to Settings, then Devices & access my sky box using my phone which is attached to my account. But the only options is sky then devices is the option to delete my devices. I was on the phone nearly 40 mins with a technician trying to figure out why I can't see that option. I have re installed all the apps again incase it needed updating, but still had no look.
hi @Hjbradn115
The virtual remote on SKY Go is currently only available for ios devices. - although it is planned for Android it has not yet been released
Message posted on 16 Apr 2025 04:59 PM
yes
Message posted on 16 Apr 2025 05:01 PM
I will
Message posted on 16 Apr 2025 05:27 PM
@Njie wrote:I will
Yes you will what?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 21 Apr 2025 04:30 PM
- Using mobile as remote
Message posted on 21 Apr 2025 05:30 PM
@Mark549 the latest version of the Sky go app now has a remote available for android and IOS
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Apr 2025 05:09 AM
Well this is certainly vying for most confusing thread in history.
Message posted on 22 Apr 2025 05:42 PM - last edited: 22 Apr 2025 05:43 PM
Yes, under the Sky Go app there's a small icon in the top right-hand side, this is the remote, click on this & it's the same layout as a standard remote.
I don’t work for Sky.
If I have helped then please leave a like.
Message posted on 25 Sep 2025 11:57 PM
Any knowledge of when this will become available? This would be a godsend.
Message posted on 26 Sep 2025 05:42 AM
It should be available now.
Message posted on 26 Sep 2025 06:45 AM
My bad. I was referring to the Android version, not ios.
Message posted on 26 Sep 2025 06:48 AM
hi @DiMach6695
This is an old discussion, the android version was updated to include the virtual remote a couple of months or so ago, thus it should be availble for you.
Message posted on 26 Sep 2025 06:59 AM
@DiMach6695 wrote:Any knowledge of when this will become available? This would be a godsend.
The post above on the 21st April says the Android version was already released back then.
Message posted on 26 Sep 2025 10:41 AM
I can assure you I have updated the app and it's still not showing on the My Sky app for android, otherwise I wouldn't have asked.
