Discussion topic: Urgent
This message was authored by: WAYNELESLIE
Urgent
I have 2 communal TV boxes does this cause a problem for the engineer who is coming to install Sky Q?
Re: Urgent
@WAYNELESLIE
What do you mean by two communal TV boxes? What is your current set up?
Avatar for WAYNELESLIE
2 separate communal TV systems
Re: 2 separate communal TV systems
@WAYNELESLIE
So you haven't got your own dish and your (presumably Sky+ system) is serviced by a communal dish?
Re: Urgent
hi @WAYNELESLIE
If you have 2 separate SKY HD boxes and upgrading to SKY Q you need to be aware that SKY Q works significantly differently
Only the main box stores the recordings - the second 'Mini' box works by a network connection (usually wifi) to the main box
All recordings on the main box are accessible by both boxes - except UHD recordings as minis cannot handle these.
There is no user profile system
BTW your existing recordings will not be accessible after the upgrade (except purchases which can be re-downloaded)
Re: Urgent
my Xbox hasn't been installed yet I'm talking about what needs to be accessed to install it
Re: Urgent
if you have a communal system then the engineer is likely to need access to it to be able toi install an 'adapter' unless the system is already capable of supplying SKY Q capable SCR signals
If this is the case you will need permission to access the communal system
(BTW I assume you mean Q box)
Re: Urgent
There is access to 2 communal TV systems so won't the engineer want to know which 1 to put the adapter in?
Re: Urgent
He/she has a choice of 2 installation points
Re: Urgent
@WAYNELESLIE  You may have 2 access points but it will be the same communal systems, it's not 2 seperate systems.
An MDU Trained installer will know what they need to do.
Re: Urgent
@WAYNELESLIE
It is unusual to have 2 completely separate distribution systems - do you just mean 2 connection points on the wall ?
Re: Urgent
Yes I do mean 2 connection points even though it's the same system
Question
How long is the cooling off period?
Re: Question
hi @WAYNELESLIE I admit I am not too sure on the timescale but I think it may be 31 days
I must, however, point out that, except for a couple of specific reasons (mainly technical) you cannot return to SKY HD once you have been changed over to SKY Q - the option is to cancel SKY completely
Re: Question
@WAYNELESLIE
Sky Q has a 31 day cooling off period. Do we take it the engineer has been today and installed it?
