Discussion topic: Upgrade subscription message
Message posted on 20 Apr 2026 09:31 AM
The moment I press the home button on my remote, I get a message to say cannot use this service and need to upgrade my subscription. Sky customer for 25 years plus I never had this problem before, cannot even watch my recordings as upgrade message keeps appearing
Message posted on 20 Apr 2026 10:21 AM
Re: Upgrade subscription message
@welshgirl55
If you haven’t done it already it may be worth rebooting the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
