2
This discussion topic has been answered Discussion topic: Sky Q box doesn’t switch on with remote
This message was authored by: Bk26
The box will switch on if mains supply cut off and restarted. No programmes available on the Home Screen either when it restarts.
Re: Sky Q box doesn’t switch on with remote
Hi @Bk26
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Hi @Bk26
Avatar for Bk26
Thanks for the help
