Discussion topic: Upgrade message
This message was authored by: David2748
Upgrade message
Just received a new sky q box, tv works ok, but everything else says i need to upgrade, already a sky q customer?
Re: Upgrade message
@David2748
Is this whilst downloading? Are you trying to download in HD without the HD add-on?
Avatar for David2748
Re: Upgrade message
  • No, only live tv works, nothing else like Apps, recording, etc
Re: Upgrade message
@David2748 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
