Discussion topic: Upgrade Netflix
Message posted on 27 May 2023 05:55 AM
Upgrade Netflix
Trying to upgrade Netflix for a extra screen
Message posted on 27 May 2023 05:56 AM
Re: Upgrade Netflix
You haven't said what you issue is but these are the packages for Netflix via Sky:
Ultimate TV includes the Netflix Basic plan (1 screen + SD) as standard
You can upgrade to Netflix Standard (2 screens + HD) by adding the HD pack
You can upgrade to Netflix Premium (4 screens + UHD/HDR) by adding the Ultra HD pack (requires the HD pack first)
If you have any issues upgrading then give Sky a call.
Message posted on 27 May 2023 05:59 AM
Re: Upgrade Netflix
On sky q I want to upgrade to another screen so more than one person can watch
Message posted on 27 May 2023 07:45 AM
Re: Upgrade Netflix
@Ashley+bc wrote:On sky q I want to upgrade to another screen so more than one person can watch
As per the info above, you need to add the HD Pack to your subscription.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 27 May 2023 08:27 AM
Re: Upgrade Netflix
@Ashley+bc wrote:Trying to upgrade Netflix for a extra screen
How do you pay for Netflix?
Is this directly with Netflix or included with a Sky Cinema subscription?
If it's with Netflix directly then you have to upgrade with them using your Netflix account.
