Discussion topic: Unable to pause/rewind live tv
This message was authored by: Helpme2
I am unable to pause / rewind live tv. Been happening for the last couple of days
Re: Unable to pause/rewind live tv
Hi @Helpme2
This message was authored by: Michele+E+Carey
Hi @Helpme2 @oldfella
Is your package out of contract mine started playing up last week I have called sky to be told yes I am out of contract it ran out on 27th May to be told I need to upgrade spent 1 hour on phone with the lady (she was nice, but doing her job to upgrade and sell me extra products) package increase from £79/month to £87/month then say once I had said OK then go ahead to say my tv would be able to work in the next 24 hours once she had put the order through then proceed to book in a slot to get me the new box and mini box I don't want with additional multi-room i dont need but it's a free upgrade and the slot is in middle of August so 2 months away I told her cancel I will go to another supplier for everything.  Then she tried to back peddle saying we'll there may just be a technical issue with the box and she would give me customer services number to that i said goodbye and now am sat here fuming and deciding to just ditch sky altogether.
This message was authored by: Rupert45
Will  ot pause
This message was authored by: SuperMatt
Posted by a Sky employee
Hello, @Rupert45. I'll send you an invite to a private chat shortly and we can help you.
Just look out for the colourful bubble to start the conversation. Please be aware conversations automatically close if there is no response within 48 hours. Here's more information on how Community Messaging works - https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147#M141
