19 Nov 2023 11:10 AM
I am unable to pause / rewind live tv. Been happening for the last couple of days
19 Nov 2023 11:14 AM
Hi @Helpme2
04 Jun 2024 02:17 PM
Is your package out of contract mine started playing up last week I have called sky to be told yes I am out of contract it ran out on 27th May to be told I need to upgrade spent 1 hour on phone with the lady (she was nice, but doing her job to upgrade and sell me extra products) package increase from £79/month to £87/month then say once I had said OK then go ahead to say my tv would be able to work in the next 24 hours once she had put the order through then proceed to book in a slot to get me the new box and mini box I don't want with additional multi-room i dont need but it's a free upgrade and the slot is in middle of August so 2 months away I told her cancel I will go to another supplier for everything. Then she tried to back peddle saying we'll there may just be a technical issue with the box and she would give me customer services number to that i said goodbye and now am sat here fuming and deciding to just ditch sky altogether.
