Discussion topic: Unable to connect to sky mini box
This message was authored by: Scream129
Engineer came to provide fast fibre unable to do so will be back later today or tomorrow  now I'm  unable to connect to the mini sky box up stairs
Re: Unable to connect to sky mini box
Hi @Scream129
Assume you have the white Sky Max router.
If you do,  you need to connect your main Q box as a 3rd party router using SSID and Password for the router 2.4 Ghz band.
Also minis need to be connected by WPS to the main Q box and not the router.
Avatar for Scream129
No got black router on screen    you don't have the required subscription to use sky q mimi been in touch said have subscribed and to phone 03337591018?
No got black router on screen YOU DONT HAVE THE REQUIRED SUBSCRIPTION TO USE A SKY Q MIMI BEEN I N TOUCH WITH THEM SAID I WAS UP TO DATE AND TO PHONE you
Not phone here @Scream129
This is a Customer forum and you are not contacting Sky here.
Regarding your issue
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
