2
This discussion topic has been answered Discussion topic: Ultra HD
This message was authored by: Woodside28
Ultra HD
Some films on Sky cannot be played because screen says I need a UHD TV to wtch.  But I do have a 4K TV.  Screen message also says to change settings press the red button. What red button? The only red button on the remote is the record button.
This message was authored by: nigea99 Answer
Re: Ultra HD
hi @Woodside28
Please may I ask which SKy product you have ?
You have posted in SKY Q - the remotes have a red button (on the latest remotes below the mute button)  & I don't recall ever seeing a message to use the red button to change resolution
If you do have SKY Q then the resolution is set in
Home - Settings - Setup - Audio Visual - Picture Resolution
Re: Ultra HD
hi @Woodside28
Avatar for Woodside28
Re: Ultra HD
Found button and it worked.  thanks
