Discussion topic: Sky Q mini box is broken
Message posted on 17 Sep 2025 10:57 AM
Sky Q mini box doesn't work
Message posted on 17 Sep 2025 11:13 AM - last edited: 17 Sep 2025 11:13 AM
Re: Sky Q mini box is broken
'Doesn't work' isn't a lot to go on...
Any lights? Error messages? Smashed up into bits?
Message posted on 17 Sep 2025 11:49 AM
Hi @JayDoogan
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
