This discussion topic has been answered Discussion topic: ULTRA HD
Message posted on 19 Aug 2023 10:46 AM
When I switch my sky Q to ultra hd a few days later it resets itself back to 1080p very annoying
Message posted on 19 Aug 2023 10:54 AM
Hi @hendersonhouse It appears to be a common problem. Do you have a standard setup, like a short high speed HDMI lead?
Message posted on 19 Aug 2023 10:59 AM
Re: ULTRA HD
Yes standard setup
Message posted on 29 Oct 2023 12:18 AM
Re: ULTRA HD
Message posted on 29 Oct 2023 12:20 PM
Re: ULTRA HD
To change your standby settings:
Press Home on your Sky Q remote and select Settings > Setup > Preferences > Standby mode, and select the setting you want. I personally have all my boxes set to NONE. This may well retain the relevant settings for you.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 03 Apr 2024 12:42 PM
Re: ULTRA HD
Might be the lead, We just had Sky Q installed , our TV is ultra hd but the installer could not get the box to connect to ultra hd setting said the box was too powerful, the message it came up with on the screen said the ultra hd lead supplied was fine, I purchased an good quality
8 ultra hd lead just 1 metre long and now it connected to ultra hd
