14
This discussion topic has been answered Discussion topic: UHD on TCLP8K tv
This message was authored by: Russell2206
UHD on TCLP8K tv
Hi, I have recently purchased a TCL P8K tv and cannot get UHD to work from a sky q box. Can anyone please help with settings I need to check/change on the tv to allow this?
thanks Russell
Avatar for Russell2206
This message was authored by: Russell2206 Answer
Re: UHD on TCLP8K tv
Managed to solve the problem...turned off the Judder reduction function in the audio visual setting and they connected up straight away🤦🏻‍♂️
thanks Russell
hi @Russell2206
Have you used 4K on another TV or is this the first time - if the 1st time check your box:
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
If it is a non UHD you would need to upgrade it (SKY usually charge around £99)
If it is a UHD box then can you select 2160p at all ?
It is a 32B2xx 2TB box and was showing UHD on an LG tv
Sorry, meant to say when I try to change picture resolution to 2160p for both 10 and 8 bit I just get a black screen
Using the same HDMI cable?
Yes, the one supplied with the Q box with the pink end
@Russell2206
I would have thought any modern 4K/8K Tv would allow 4K by default but always worth checking the settings for the HDMI input
This message was authored by: Me134
Silly question perhaps but do you subscribe to UHD from Sky? Is it on all channels?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Yes, definitely subscribed to UHD, as I said before, it worked in an LG, brought a bigger tv and now it's not
Try a better 8k certified cable, they don't cost much
This message was authored by: DaveDrizen
thanks Russell
Can you check between you old tv and your new one to set what differences in the need picture resolution settings?
@Russell2206 Glad you got it sorted and thanks for letting us know what the cause was
Ok that's completely bizarre. All that does is  change the output to 60fps on some apps. Doesn't even affect normal menus and TV which still run at 50.
This message was authored by: CLW4
Out of interest, does the TCL P8K show UHD in 10-bit well? I had Sky stream so have to use 10-bit as no option to change and my current Samsungs peak brightness is too low to handle UHD well. I'm looking int new TV's and wondered how the P8K handles Sky sports UHD for example?
