Discussion topic: UHD issues
Message posted on 14 Jan 2024 02:22 PM
UHD issues
Sky sports UHD channel has constant signal issues. Does anybody have a fix?
Message posted on 14 Jan 2024 02:25 PM
Re: UHD issues
At this point yours is the only post. I'm watching the game but on my mini box so HD.
Message posted on 14 Jan 2024 02:27 PM
Re: UHD issues
I've been noticing it a lot recently. Sometimes the channel won't load at all
Message posted on 14 Jan 2024 04:48 PM
Re: UHD issues
For some reason my Sky Sports Main Event UHD channel on 401 has changed to HD and the UHD channel is on 858. It's the second time since Christmas this has happened, last time the 2160 10 bit had defaulted back to 1080 HD but it's ok this time so I don't understand why UHD has just moved?
Message posted on 14 Jan 2024 05:28 PM
Re: UHD issues
@Lee+Curtis Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Jan 2024 05:33 PM
Re: UHD issues
Thankyou Laing1 yes I must do that, thanks
