Discussion topic: UHD flickering when watching apps on sky Q
Message posted on 25 Feb 2025 06:11 PM
I've been experiencing a flickering issue when using apps on my Sky Q box when the sky Q resolution is set to UHD. The flickering occurs across all apps, but when I switch the resolution to HD, everything works fine. This issue has only started recently, as UHD playback used to work without problems. And it should work when set to UHD problem is only with the apps on sky Q iv tried rebooting the sky box and updating and app refresh but not worked any one know how to fix it what else I could try thank you
Message posted on 25 Feb 2025 06:30 PM - last edited: 25 Feb 2025 06:30 PM
Re: UHD flickering when watching apps on sky Q
What HDMI lead are you using?
The bandwidth required for UHD is significantly higher than HD so any cable issues would show up...
Message posted on 26 Feb 2025 09:09 AM
@PandJ2020 wrote:What HDMI lead are you using?
hi it's the sky Hdmi the one that came with the box? is it worth getting another one made for 4k/UHD thanks
Message posted on 26 Feb 2025 09:36 AM
Just tried a different HDMI and still doing it and had a new sky Q box and still issue please help
Message posted on 26 Feb 2025 10:02 AM
@Anonymous wrote:Just tried a different HDMI and still doing it and had a new sky Q box and still issue please help
If you've eliminated the Q box and cable then it suggests the TV...
Tried a different HDMI input?
Message posted on 26 Feb 2025 10:31 AM
One other thing you could try is turning juddering settings option to on/off on your Sky Q box.
- Press Home on your Sky remote and select Settings, followed by Setup and then Audio visual.
- Change Judder Reduction to On.
Would suggest after making that settings change, repowering your TV and Sky Q box.
Message posted on 26 Feb 2025 10:37 AM - last edited: 26 Feb 2025 10:38 AM
@lettice wrote:One other thing you could try is turning juddering settings option to on/off on your Sky Q box.
Worth trying - the native refresh rate is 50Hz. Turning on judder reduction sets it to 60Hz.
But also bear in mind the TV may be performing post-processing. Worth trying to turn this all off, such as frame interpolation etc. Some TV's make a dogs dinner of post processing if the Q has 'forced' the refresh against the native rate. This might be the 'flickering' effect you are seeing.
I run my TV in film maker mode which disables the majority of such processing.
As ever, always use the TV native app if you can as this will almost always be better.
Message posted on 28 Feb 2025 10:10 AM
thank you all for your help i'll try all the steps you have mentioned
Message posted on 17 Aug 2025 01:10 PM
I had exactly the same problem and have been putting up with for quite a while but before contacting sky, because they would just say have tried a different hdmi cable I thought let's give it a go , with a long background in electronics and computers I was very sceptical about doing this but ordered an 8K UHD cable from eBay £8.40. No need to go silly and let's just say I am glad I didn't promise to eat my hat, if it didn't work but since the change I have had no problems.
