Discussion topic: UHD/ HDR
Message posted on 14 Mar 2023 02:54 PM
UHD/ HDR
Irecently chnaged my tv for a newer model of a sony bravia and now the test card in the hdr info within sky Q has an HDR test card but on viewing the test card area for HDR which should be clear fine black lines is still very fuzzy. my settings are all done for hdr 10 bit etc . Anyone able to help in this matter?
Message posted on 14 Mar 2023 02:55 PM
Re: UHD/ HDR
Hi @CBBT Sky Q uses HLG, not HDR10.
Message posted on 14 Mar 2023 03:07 PM
Re: UHD/ HDR
My model is
it says it will do HLG??
Message posted on 14 Mar 2023 03:52 PM - last edited: 14 Mar 2023 03:57 PM
Re: UHD/ HDR
@MightyQuinn wrote:Hi @CBBT Sky Q uses HLG, not HDR10.
HLG is 10bit too 😉
Might be some sort of processing the Sony is doing on the incoming image. Worth checking through its menus to turn off any shenanigans.
Have to say on my Panny OLED it's not perfect on that UHD section, you can see the individual lines but there's a little haziness to it. Possibly even compression artefacts.
Message posted on 14 Mar 2023 04:14 PM - last edited: 14 Mar 2023 05:13 PM
Re: UHD/ HDR
@Chodley wrote:
HLG is 10bit too 😉
Hi @CBBT
I have a Panasonic OLED too & simarlarly I can just about make out individual lines but I have to get reasonably close to the TV to see them rather than it appear as almost solid grey
Sorry I can't help with anything specific to check @CBBT but dont rely on being able to distinguish the fine detail from a distance
BTW If you are getting the test card then your TV is properly set up for HLG - I think the way you have worded your opening may have confused @MightyQuinn (mentioning HDR & 10 bit next to each other)
