Discussion topic: Tv
This message was authored by: Mahsam
Tv
How can I contact customer service
Re: Tv
@Mahsam first Is the issue something we can help with and save you a call?
These are the current methods for contacting Sky…
▪️call by dialling 150 (free) from either a Sky Talk landline or a Sky mobile.
Calls to Sky will start automated which may offer you the online help route (see below) or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
▪️online help via this link
https://www.sky.com/help
▪️ Sky Assistant is also available at the top of sky.com/help for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
▪️Social Media You can also get in touch with Sky via the messaging services on: Facebook or Instagram (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Avatar for Mahsam
Cancel the sky sport
I want to cancel my contract. Can you please give me the phone number?
Re: Tv
@Mahsam  You may not be able to cancel if you're in contract but the available contact options are detailed in my post above
Re: Cancel the sky sport
@Mahsam
If it's just Sky Sports you wish to cancel you need to contact Sky giving the standard 31 days notice. If you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling in using the number that should appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
@Daniel0210  Beware there are duplicate threads in play from op
@SKY1992bf
Good spot.
@Mahsam
No need for another thread. As you can see it just causes duplicate replies and confusion.
If it's just Sky Sports you wish to cancel my post above is solution.
