Discussion topic: Tv
This message was authored by: Sonya37
Tv
Record light remains on when not recording anything and can not pause or rewind TV.
Re: Tv
@Sonya37
Have you downloaded a programme which has become stuck? If so stop it and completely delete it.
Avatar for Sonya37
Re: Tv
No we are not recording anything at all. We have just checked.
We have lost all our recordings and can no longer pause and rewind TV
Re: Tv
@Sonya37
Have you tried rebooting the box?
Do the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for Sonya37
Re: Tv
I have just done this thank you. It now says when I try to pause the TV there is a problem with the hard disk drive.
Re: Tv
Hi @Sonya37
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
