17
This discussion topic has been answered Discussion topic: Tv signal problem
This message was authored by: Steve+quinnell
Tv signal problem
For the past 5 to 6 days my tv signal has just been flickering on most of my channels. I'm just wondering if I can get a discount of my bill for the interruption it has caused.
S.grattan
Re: Tv signal keeps dropping out
@Steve+quinnell
No signal or no satellite signal?
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Re: Tv signal problem
It depends on what the issue is and Sky are unlikely to consider any credit prior to reporting it to them...
Is it a satellite reception issue do you know?
Avatar for Steve+quinnell
Level 2 icon
Yeah most probably as my channels are back now but it just happens out the blue. Thanks for helping
S.grattan
If it's your own dish then it's likely to be a small alignment issue.
Flickering doesn't sound like a dish thing. That's usually binary - either working or "no sat signal".
Level 2 icon
Hello I have a sky q box with admin lead and most channels not working. I've tried everything and still no signal
S.grattan
@Steve+quinnell
Level 2 icon
Thankyou Daniel for your help I need to book engineer
S.grattan
Level 2 icon
Tv signal
Anyone having problems with sky Q tv signal in portsmouth area
S.grattan
@Steve+quinnell
You seem to have this issue frequently and ask each time on here and we provide the same advice. Have you called Sky to arrange an engineer?
Edit- your three threads have been merged and the post you marked as the answer last week is still relevant.
Re: Tv signal
Do you think this could be relevant?
Level 2 icon
Yes most definitely I bet sky love Britain due to weather because everyone is paying a lot of money and most of time you can't watch live tv due to weather. A massive thankyou for your help have a great day
S.grattan
Level 2 icon
Yes they have  been out its just really bad weather in my area should be fine by tomorrow
S.grattan
@Steve+quinnell
But if your dish has moved, even slightly, you'll have problems again very soon.
Level 2 icon
I have a communal dish as I'm in flats
S.grattan
Answered - Go to Answer
