Discussion topic: Cant connect to router from sky q box. Tried resetting but it says no ip address obtainted
Message posted on 26 Jan 2025 03:21 PM
Ive tried resetting everything and nothing works.
Message posted on 26 Jan 2025 03:26 PM
							Re: Cant connect to router from sky q box. Tried resetting but it says no ip address obtainted
Hi @Brucelee147
Did you complete the following ?
Message posted on 26 Jan 2025 03:29 PM
Hi. Yes i have tried this already. Thanks
