13
This discussion topic has been answered Discussion topic: Tv shuts down
This message was authored by: Roy+wx
Tv shuts down
Tv will shut itself down and unable to restart. Once this has happened we are unable to reboot tv until it feels like it....
Avatar for Roy+wx
Level 2 icon
This message was authored by: Roy+wx Answer
Re: Tv shuts down
Press button on tv, light flashes until tv comes on. Pi ture comes up momentarily. Then switches off. Tv light flashes slowly until repress to retry power recycle
Nothing on remote works
Re: Tv shuts down
Hi @Roy+wx   Do you mean the TV, or the Sky Q box?
Avatar for Roy+wx
Level 2 icon
Re: Tv shuts down
TV Will shut down and needs to be powered off to try restarting. 9 ti.es out of 10 screen will flicker and then shut down again
Re: Tv shuts down
Hi @Roy+wx   Please answer the question. This is a help community for the Sky Q box, you will need to talk to your TV manufacturer for help with your TV.
Avatar for Roy+wx
Level 2 icon
Re: Tv shuts down
I do not know at present whether is Q box or tv
Re: Tv shuts down
Hi @Roy+wx   Describe exactly what happens when you say "TV shuts down". Does the TV turn off completely or is it simply a blank screen. What happens to the Sky Q box, does the light remain on green? Do you see any error messages etc.
Re: Tv shuts down
Try pressjng the menu button on the tv remote when it happens. Simple diagnosis. If that works, it's the Q box that's locked up/shutdown.
Avatar for Roy+wx
Level 2 icon
Re: Tv shuts down
Pressing any buttons on remote before or whilst it is in the process of shutting down makes no difference. To try again you have to power off and on again
Re: Tv shuts down
I don't mean while it's happening. I meant afterwards to confirm the TV is still working and operating normally so you know it's the Q box that has gone wrong. Hence "diagnostic".
Avatar for Roy+wx
Level 2 icon
Re: Tv shuts down
Re: Tv shuts down
Ok sounds like you need to talk to the TV supplier.
Avatar for Roy+wx
Level 2 icon
Re: Tv shuts down
Thnx. I have engineer booked this afternoon
Re: Tv shuts down
A Sky engineer or from the TV manufacturer?
Avatar for Roy+wx
Level 2 icon
Re: Tv shuts down
  • TV engineer
