Discussion topic: Tv says there seems a problem with your internet on sky Q but everything else in the house is workin
This message was authored by: Harlequin13
We have not had any tv at all since last night the tv says it is the internet however you do not need internet to watch normal tv also all our other devises are working from the internet
including a tv in another room not on sky that works just from the internet
Re: Tv says there seems a problem with your internet on sky Q but everything else in the house is wo
Hi @Harlequin13
Have you tried rebooting your Q box?
If you still have the issue then try reconnecting your Q box.
