Discussion topic: Sky q mini box keeps freezing
Message posted on 30 Nov 2023 09:55 PM
I've just been told by my family that our sky q mini box picture has been freezing on and off for months.. They have turned it off at the wall and back on again many times. This can help for a while but the problem soon re surfaces. It has now got to the point of being unwatchable. The main sky q box is ok. Broadband is good also.
Message posted on 30 Nov 2023 10:09 PM
							Re: Sky q mini box keeps freezing
Hi @walkthedog
Reboot the mini as above.
Message posted on 01 Dec 2023 09:56 AM
Hi oldfella. Thanks for your quick reply. I've tried your suggestions. I will give it the day to see if the problem has gone. If not I will be getting intouch with sky directly. Thanks again 👍🏻
Message posted on 26 Feb 2024 09:14 PM
I've had this problem for quite a while now (2 years) only on one mini box. Done all the above suggestions, got the booster, had an engineer etc. and still doesn't work. If you get it solved please let me know. 🙏
Message posted on 16 Jun 2024 09:52 AM
Hi,
tried your advice. Seems ok sofar.
Thanks for tour help.
George.
