Discussion topic: Tv remote
Message posted on 16 Apr 2023 10:37 AM
							Tv remote
Samsung tv BU8000 won't turn off with sky Q remote but works everything else
Message posted on 16 Apr 2023 10:42 AM
							Re: Tv remote
You have to hold the power button for about 3 seconds to send a power off signal to the TV.
If that doesn't work then try other Samsung codes.
Message posted on 18 Apr 2023 08:01 AM
							Re: Tv remote
Yeah thanks I've tried them all and it still doesn't work the tv is Samsung ue60bu8000kxxu
Message posted on 18 Apr 2023 08:04 AM
							Re: Tv remote
@jodreadful wrote:Yeah thanks I've tried them all and it still doesn't work the tv is Samsung ue60bu8000kxxu
Have you carried out the pairing process?
Message posted on 18 Apr 2023 10:37 AM
							Re: Tv remote
Yes 1-3 and 7-9
Message posted on 18 Apr 2023 11:15 AM
							Re: Tv remote
@jodreadful wrote:
Yes 1-3 and 7-9
Wrong way round @jodreadful
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 18 Apr 2023 11:59 AM
							Re: Tv remote
Yeah thankyou done that as well everything works except turning it off
