1
This discussion topic has been answered Discussion topic: Tv guide
This message was authored by: Janine991
Tv guide
The 'waiting for tv schedule' keeps coming up, it's like it has no internet but it does.  The home page works but I can only get one channel as the guide is missing
This message was authored by: mr.tickle Answer
Re: Tv guide
The EPG guide data is only downloaded from the satellite, and always has been. So you need a working satellite signal.
Non-essential flourishes (like the images used as thumbnails in your Planner) come from the internet, but not the core guide data.
The quickest thing to try is a reboot. There' no need to pull the power, just go to Home/Settings/Setup/Preferences and change "Maximum number of recordings" from 5 to 6 (or 6 to 5 if it's already on 6). That will then ask  you to confirm and reboot without needing to pull plugs out.
HTH
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
Re: Tv guide
HTH
