Discussion topic: Toshiba TV cannot switch off using Sky remote
Message posted on 18 Aug 2023 02:05 PM
Hi all
i have a new Toshiba TV and have paired the Sky remote. I can switch the TV on, volume, change inputs etc...
however I cannot switch the TV off. I get a 'Power off - do you want to shut down?' message. I cannot press ok as the sky remote doesn't have the option.
any ideas?
Message posted on 18 Aug 2023 02:35 PM
Re: Toshiba TV cannot switch off using Sky remote
@Martyn+Struebig wrote:
Hi all
any ideas?
@Martyn+Struebig sometimes if you press the off button too long it will bring this up try only pressing the off button on the Sky remote for 3 to 4 seconds if it still does it it may be a setting on the TV what model of Toshiba TV is it that you have
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 15 Oct 2023 09:03 AM
Mine is doing exactly the the same, and the annoying thing is, you then can't use the sky remote to confirm you want to turn it off and have to use the original TV remote. Can anyone help please ?
Message posted on 15 Oct 2023 11:43 AM
The suggestion about 3 seconds works perfectly. Thank you
Message posted on 19 Mar 2024 06:43 AM
i'm getting the same message as you so I don't know what to do either
can anyone help me
Message posted on 19 Mar 2024 06:46 AM
Can anyone tell me if there's a suggestion to turn off the power off mode, please
