15
This discussion topic has been answered Discussion topic: Sky Q remote no longer controlling Toshiba TV
This message was authored by: mcnulty9
Hi, first post here - everythings been running smoothly so far with a quick switching it on and off.
About a month ago my Sky Q remote stopped controlling my TV (Toshiba - 65UL2063DB), I've went to set it up again with the model number - no use. I've went through all 14 manual tests for Toshiba and it's still not working. Has this TV been removed from a compatible list or is there a fault with my remote?
Batteries have been changed between testing.
Avatar for mcnulty9
This message was authored by: mcnulty9 Answer
Re: Sky Q remote no longer controlling Toshiba TV
Got a new remote through the post and was able to set-up 🙂
@mcnulty9 try using vestel as the maker as i am sure they now make toshiba tv's
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @mcnulty9
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
If you cannot get it to pair try Other brands in the setup pairing
You'd think an existing model that worked wouldn't change though?
Avatar for mcnulty9
Hi @oldfella !
Thank you so much for your quick reply. I've just followed your instructions, unpaired and paired, and all 40 Other brands and still unsuccessful.
Avatar for mcnulty9
Tried that there, no luck!
Avatar for mcnulty9
@Laing1 No luck I'm afraid.
Does the Tosh original remote work?
Avatar for mcnulty9
@Chodley Yeah the remote for the TV works.
Totally bizarre. Have you tried with a 2nd remote from a mini, if you have one?
Avatar for mcnulty9
@Chodley Yeah I think it's strange too, considering I was able to pair the remote with the TV previously. I only have the one sky box so no other remotes, think I'll give the team a wee call. Thanks for your help.
I've escalated on here for you. Look out for a blue chat bubble.
This message was authored by: Mr+Flibbles+86
Thanks for escalating this. We’ve sent an invite to chat.
Avatar for mcnulty9
This message was authored by: Faye+Baker
I have the same issue but my remote stopped working to control my brand new Toshiba TV (43QA5D63DB) after just a few days. I've received a replacement remote today but still unable to pair it with my TV. Also tried Vestel but no luck.
