Discussion topic: I can’t access on demand services, and my mini boxes have no TV Guide
Message posted on 16 Mar 2024 10:52 AM
I can't access on demand, and my mini boxes have no TV Guide or signal.
The error is as follows:
"Becasue of a technical issue, your download couldn't be completed."
It doesn't seem to be a broadband issue, as I can access BBC iPlayer through the box.
Message posted on 16 Mar 2024 10:58 AM
Re: I can’t access on demand services, and my mini boxes have no TV Guide
I have powered-off and reconnected everything, in the following order:
All power off
Sky Q box on
Wait 2 mins
Mini box on
Message posted on 16 Mar 2024 11:27 AM
All power off
Sky Q box on
Wait 2 mins
Mini box on
Try a Reset Settings in the main Q box hidden menu.
Message posted on 19 Mar 2024 06:47 AM
Hi again,
I tried the above and it didn't work, unfortunately. I will try to get in touch with Sky.
But thank Lou for your help.
Graeme
