Discussion topic: To view on another tv
This message was authored by: R6+CRS
Hi looking to find out how to watch sky on a tv upstairs while the sky q box is down stairs.
I've bought the two small converters HDMI to RJ45/cat5 cable.
plugged the TX one into the HDMI port on the sky q box & the other one RX into the HDMI port 3 on the tv up stairs. At first I got the picture up stairs but no sound. I moved the RX to HDMI port 1.
I'd then get the picture & sound but the screen after only a few seconds would go black for a while then come back on & do the same again.
This message was authored by: F1Jon97
Re: To view on another tv
Hmmm it could be quite a few things causing that issue.  1st thing might be the cat5 cable, maybe too long or its slightly damaged.  Does it go into a switch then upstairs?  Could try rebooting the switch.  Could also try powerline adapters.
I have a mini box which was awful using wifi so I connected the Q box to the router via cat5 then put a powerline adapter connected to the router and another one at the other end into the mini box.  Then I disabled wifi on both Q boxes and its been working almost flawlessly since January.
Years ago I had an old VBox and using a HDMI RF Modulator I took the HDMI output and converted it into a coaxil (like Freeview) signal then into the VBox which sent what was on the Q box around the house via IP.  It worked well apart from the horrible 2 second delay when pressing the remote and a slight drop in quality.
I much prefer having the Mini now that it works on ethernet with powerline adapters as its just as good as watching on the main box
This message was authored by: bob1234
@R6+CRSThose converters are very variable some work some don't, Q is not intended to work that way, far better to get a mini box and multiroom subscription from Sky. I am not even sure you can connect it the way you are trying to.
It is worth bringing your other TV  near to the main box and trying a direct cable, when it does not work you will know  there is no point in bothering with extenders etc.
