Discussion topic: There is a technical problem. Please try again later.
This message was authored by: SteveP72
My sky keeps stopping and displaying the message "There is a technical fault. Please try again later ", this is happening every five minutes.  I've tried resetting to factory reset but nothing seems to work.
Has anyone else had this problem and been able to fix it? Sky customer support seems none existent.
Re: There is a technical problem. Please try again later.
Hi @SteveP72
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
