5
This discussion topic has been answered Discussion topic: The home button is changing my tv hdmi input
This message was authored by: Paul+Wareham+69
Why
its simple the home button on my sky Q remote changes the hdmi of my Sony tv from hdmi 1 to hdmi 4
Re: The home button is changing my tv hdmi input
@Paul+Wareham+69 wrote:
Why
Hi @Paul+Wareham+69
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Also try rebooting your Sony TV.
Latest models will reboot if you hold the Power button on the remote for more than 3 seconds.   Otherwise disconnect power lead for 30 seconds and then reconnect.
Why
Hi @Paul+Wareham+69
This message was authored by: Amy0293
Just incase anyone else has this issue... mine was doing the same and to fix it I went to settings on my sky stream puck, then to startup and standby and switched hdmi control to off. It was fixed right away
@Amy0293
The OP's issue was on Sky Q not Stream/Glass.
Was it switching to an hdmi input that the Stream wasn't connected to?
This message was authored by: EleriBeth
Thanks so much! This helped me 😁
