5
Discussion topic: The home button is changing my tv hdmi input
This message was authored by Paul+Wareham+69 This message was authored by: Paul+Wareham+69
Why
its simple the home button on my sky Q remote changes the hdmi of my Sony tv from hdmi 1 to hdmi 4
This message was authored by oldfella This message was authored by: oldfella Answer
Re: The home button is changing my tv hdmi input
@Paul+Wareham+69 wrote:
Why
Hi @Paul+Wareham+69
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Also try rebooting your Sony TV.
Latest models will reboot if you hold the Power button on the remote for more than 3 seconds.   Otherwise disconnect power lead for 30 seconds and then reconnect.
Why
Hi @Paul+Wareham+69
This message was authored by Amy0293 This message was authored by: Amy0293
Just incase anyone else has this issue... mine was doing the same and to fix it I went to settings on my sky stream puck, then to startup and standby and switched hdmi control to off. It was fixed right away
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Amy0293
The OP's issue was on Sky Q not Stream/Glass.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
This message was authored by Chodley This message was authored by: Chodley
Was it switching to an hdmi input that the Stream wasn't connected to?
This message was authored by EleriBeth This message was authored by: EleriBeth
Thanks so much! This helped me 😁
